Automotive Where Can I Find DIY Car Radiator Kits and Cores for Aluminum Radiator Design?
Designing a car radiator involves understanding key factors such as size, cooling efficiency, and material choice, particularly for a race car with limited space. The discussion highlights the challenge of sourcing affordable aluminum radiator components, as commercial options can be expensive. Participants are encouraged to share resources for DIY radiator kits and aluminum cores, which are essential for custom builds. The need for welding tank ends onto cores is also emphasized, indicating a preference for a hands-on approach. Overall, the thread seeks practical advice and sources for creating a customized aluminum radiator.
5aizal
Hello I am new here,
Can anyone share with me on how to design car radiator.:confused:
Welcome to the PF.
What are your thoughts on this? What kinds of things are important in the design of a car radiator? Is this for schoolwork?
Bump to an old topic. I've been interested in building a radiator for my race car. It sports a 4 stroke 1000cc motor, water cooled.
Space doesn't allow much for radiators and getting aluminum radiators to fit the hole cost a lot from top name companys.
I have been searching for cores etc? So i can weld on my own tank ends etc but I have had no luck.
Does anyone have information on DIY radiator kits (aluminum) or where to find the aluminum cores etc
Chris,
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
