Spacetime line element to describe an expanding cube
The discussion focuses on creating a spacetime line element for an expanding cube, specifically one that elongates along the z-axis while maintaining a constant x-y shape. Participants clarify that the line element must be spatially homogeneous, meaning it should not vary with x, y, or z coordinates. To account for the cube's expansion, at least two scale factors are necessary: one for the z-direction and another for the x-y plane. The proposed line element includes a scale factor a(t) to represent this expansion, but further understanding of how to apply these conditions is needed. Comoving coordinates are mentioned as a way to conceptualize the stretching in the z direction while keeping the x-y dimensions fixed.
lailola
Hi, I have to write a spacetime line element for the shape of a cube of cosmological dimensions. This cube is expanding like this:
i)With time, the cube becomes elongated along the z-axis, and the square x-y shape doesn't change.
ii)The line element must be spatially homogeneus. (I don't know what this means).
I think there must appear the scale factor a(t) because of the expansion, but I don't know how to use the conditions of the expansion.
For a cilinder, I would use something like this: dS^2=-dt^2+a^2(t)(R^2 d\theta^2+dz^2) where R is the radius of the cilinder.
Any help?
Thanks!
Space news on Phys.org
Spatially homogeneous means that your universe is translation-invariant. In other words, the metric cannot depend on x,y or z.
If the cube gets elongated in the z-direction, then you need at least two scale factors: one for z and one for x and y.
Any help?
Thanks!
ds^{2} = -c^{2}dt^{2} + dx^{2} + dy^{2} + a^{2}(t)dz^{2}
\dot a > 0
\dot a > 0
Thanks for your answers.
Ruta, I don't get why that line element satisfies the first condition.
This is certainly something you need to figure out before you can answer the question.
How would you know if something satisfies that condition? What does the condition mean, physically?
It means that the area of the cube in the x-y plane is constant for every z. Doesn't it?
Do you understand comoving coordinates? Those in the z direction are being "stretched" while those of in x-y plane remain fixed.
