Problem in Vector Resolution and Component
Vector resolution involves breaking down a vector into its components along the X and Y axes, known as Ax and Ay, respectively. The projection of a vector on an axis is the shadow it casts on that axis when light is shone directly above it, leading to Ax being the horizontal projection and Ay the vertical projection. The equation Ax + Ay = A is a misunderstanding; the correct relationship is that the magnitudes follow the Pythagorean theorem, where (Ax)² + (Ay)² = A². This distinction emphasizes that while the components add up vectorially, their magnitudes do not simply sum to the original vector's magnitude. Understanding these concepts clarifies the relationship between a vector and its components.
avistein
I cannot understand what is vector resolution.It is said in the book that ON is the resolved part of A along X axis.It is also known as the x-component of A or the horizontal component of A.Ax may be regarded as the projection of A on X-axis. OM is the the resolved part of A along Y-axis.It is also known as the y-component of A or vertical component of A.The vertical component of A may be regarded as the projection of A on Y-axis.Now what is that projection? Is it the image of A on X-axis or Y axis?
Then why Ax+Ay=A and not A=Ax or A=Ay?If Ax and Ay are the images of A on X and Y resp. then the magnitude of Ax and Ay should be same as A,but no, why? Please explain me.I am very much confused.
If A = (a,b), then the x-axis projection is (a,0) while the y-axis projection is (0,b).
It is quite simple - don't let the terminology confuse you.
Likes 1 person
vectors are simple
Don't get muddled up. Let, me explain what projection is. Say, the vector extends from (0,0) to (a.b). Suppose, you want projection on the x-axis, take a light source and place it directly above the end of the vector, the shadow would be at (a,0). Thus the projection of the vector extends from (0,0) to (a,0). similarly, y-component would extend from (0,0) to (0,b).
And, by the way Ax+Ay ≠ A. Using the Pythagoras theorem, (Ax)2+(Ay)2 = A2.
What the book might have meant would have been, was vector Ax+vector Ay = vector A. By writing vector, I am also considering the direction. While, above, I was only talking about magnitudes. With a little practice, you would easily understand the difference between the vector and it's magnitude. So, good luck!
Likes 1 person
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
