AC & Heat Pumps: Motor Vehicle Solutions
  • Thread starter Thread starter Jobrag
    Ac Heat Pumps
The discussion highlights the inefficiency of car heating systems, which require time to warm up compared to the immediate cooling provided by air conditioning. Participants note that while it is technically feasible to implement heat pump systems in vehicles for instant warmth, cost considerations and the existing engine heat make it less appealing for manufacturers. The use of PTC heaters is mentioned as a common solution in hybrid and some diesel vehicles. Additionally, remote starters are suggested as a practical way to pre-condition vehicles in extreme temperatures. Overall, while improvements are possible, current solutions prioritize cost-effectiveness and existing engine heat utilization.
Jobrag
On a hot day the AC in my car starts working immediately pumping cool air, on a cold day I have to wait till the cooling system heats up before I get warm air. It would be perfectly possible (with the aid of a couple of solenoid valves) for the AC unit to run as a heat pump providing immediate warmth, why don't motor manufactures fit a system like that? Is it just cost?
So you don't want to use the heat generated by the engine; just loose it?
It is a big expense for something only used for 5 min per day.
Yeah it's pretty much the same old story. Anything that is physically possible can be done, but at a cost.
Simple fix, and it's found in most hybrid cars and some diesels...PTC heater.
My son in law in the cold north, uses a remote starter.
Starts his car about 5 min before he gets out of work.
This method also works for cooling the car down in summer.
It does cost some extra fuel, but if it's -20F, it's worth it.
The answer to your original question is Yes it is possible,
but the engine heat is already there, no need to squeeze
your own out of the air.
