Relationship between Kd and bonding affinity?
The discussion centers on the comparison of two dissociation constants, Ka and Kb, for a protein-ligand complex, with Ka at 4 x 10^-3 M indicating a weaker binding to ligand A, and Kb at 2 x 10^-7 M indicating a stronger binding to ligand B. The key point is that a lower dissociation constant signifies a tighter bond or higher affinity, leading to the conclusion that the free protein binds ligand B more tightly than ligand A. The conversation emphasizes understanding the equilibrium equations and the concept of half-saturation, where the concentration of bound versus unbound proteins is crucial. It is noted that at half saturation, ligand B will have a lower concentration compared to ligand A, reinforcing the idea that ligand B has a higher affinity for binding. Calculating the ratio of liganded to unliganded protein at specific ligand concentrations is suggested as a method to further elucidate the differences in binding affinities.
τheory
From a biochemical context, considering the following two dissociation reactions and their respective dissociation constants for a protein-ligand complex:
P*A + B ⇔ P + A + B, this contains the a dissociation constant called Ka = 4 x 10^-3 M
P*B + A ⇔ P + A + B, this contains the a dissociation constant called Kb = 2 x 10^-7 M
Compare the values of Ka and Kb; Does the free protein bind ligand A or ligand B more tightly? I know that a lower dissociation value means tighter bonding or "higher affinity," so the free protein should bind to ligand B more tightly, but can someone explain to me why this is the case?
Chemistry news on Phys.org
You seen to have answered your own question, so I don't know really what it is. But to explain to yourself "why this is the case" just write down the equation for the equilibrium, then ask yourself what is the ligand concentration when the protein is half-saturated, i.e. bound protein = free protein.
Your first equation contains a B on both sides, and your second an A which if they were not there would make no difference and might confuse you less.
So the question, of why one ligand binds more strongly than the other, pertains to the idea that in a system, ligand B will have a higher concentration of bound vs unbound proteins compared to ligand A at the half saturation level?
Edit: To your previous statement, I did answer my own question implicitly due to the way I phrased the original post, that was my mistake. What I meant to say was that I uncovered a principle (lower Kd = tighter bonding) from my textbook that I didn't fundamentally understand. As a result, I wanted someone to try to explain this concept.
More like at half saturation with B, will be at lower concentration than [A] will be at half saturation with A.
It does not sound like you have written the equilibrium equation as I suggested; if you do you should see what's what. To use the half-saturation point is a convenience, but a pretty essential one you will meet constantly.
It will also help you see how this works if you calculate the ratio of liganded to unliganded protein at 10-5M free ligand in cases A and B which have very different affinities.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
