Solving a DE: Finding Power Series Solutions about z = 0
Benny
Can someone please explain some steps of a worked example.
Q. Find the power series solutions about z = 0 of 4zy'' + 2y' + y = 0.
(note: y = y(z))
Writing the equation in standard form:
<br /> y&#039;&#039; + \frac{1}{{2z}}y&#039; + \frac{1}{{4z}}y = 0<br />
Let y = z^\sigma \sum\limits_{n = 0}^\infty {a_n z^n }
The indicial equation has roots zero and (1/2).
Using the substitution for y above the DE becomes:
<br /> \sum\limits_{n = 0}^\infty {\left[ {\left( {n + \sigma } \right)\left( {n + \sigma - 1} \right) + \frac{1}{2}\left( {n + \sigma } \right) + \frac{1}{4}z} \right]} a_n z^n = 0<br />...(1)
Demanding that the coefficients of z^n vanish separately in the above equation we obtain the recurrence relation:
<br /> \left( {n + \sigma } \right)\left( {n + \sigma - 1} \right)a_n + \frac{1}{2}\left( {n + \sigma } \right)a_n + \frac{1}{4}a_{n - 1} = 0<br />
What happened to the factor of z which was multiplied by (1/4) in (1)?
If we choose the larger root, 1/2, then the recurrence relation becomes a_n = \frac{{ - a_{n - 1} }}{{2n\left( {n + 1} \right)}}
Setting a_0 = 1 we find...etc
I am told that the larger of the two roots of the indicial equation always leads to a solution. However, I don't understand why a_0 is set equal to one? Is that an arbitrary selection or is it convenient?
Any help would be good thanks.
It's there, it's the \frac{1}{4}a_{n-1}. Do you see why?
I've never done problems like this before, but if you are getting this by substituting \sigma = \frac{1}{2} into:
then you should get:
a_n = \frac{{ - a_{n - 1} }}{{2n\left( {\mathbf{2}n + 1} \right)}}
Different choices of a0 will give different solutions, and you should indeed expect a family of solutions, not just one solution. Are there any given boundary conditions that might explain the choice of a0 = 1? If not, then perhaps it is just arbitrary/convenient/conventional, I don't know myself.
There aren't any ICs or BCs in the example so a_0 = 1 might have been chosen simply to illustrate the solution method. Thansk for your help.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
