Differential equation, confused on directions, F(x,y)?
mr_coffee
Hello everyone, I am confused on what they are wanting me to do here on this problem:
http://cwcsrv11.cwc.psu.edu/webwork2_files/tmp/equations/8e/03f256344c773f4cb31a6c00deae771.png
has an implicit general solution of the form
http://cwcsrv11.cwc.psu.edu/webwork2_files/tmp/equations/46/676cc60ad18cc49904f5f4ac4fa61e1.png
In fact, because the differential equation is separable, we can define the solution curve implicitly by a function in the form
http://cwcsrv11.cwc.psu.edu/webwork2_files/tmp/equations/82/62c381e72069d44ef291f5391ed7871.png
Find such a solution and then give the related functions requested.
http://cwcsrv11.cwc.psu.edu/webwork2_files/tmp/equations/57/f15a6cea760ce4906a6ec16f9d29451.png
here is my work, i think they wanted me to do, they gave no intial condition so i solved for C:
http://img39.imageshack.us/img39/1227/lastscan5vx.jpg
but it was incorrect :cry:
Well what is supposed to be the correct answer? I can't see much wrong with what you've done.
Edit: You seem to have replaced the y with x after the integration of the exponential.
thats a good question, it doesn't tell me. it will tell me if i get it right, not if i get it wrong. Whats this implicit general solution stuff do i have to take partial derivatives or somthing?
WHY do you keep writing \frac{1}{e^{-2x}}? Surely you know that \frac{1}{e^{-2x}}= e^{2x}
Your instructions were to write the answer as F(x,y)= K and then write it as F(x,y)= G(x,y)+ H(x,y)= K
You already have 5e2x- arcsin(x/2)= K. Can't you just look at that and pick G and H?
Going from the second line to the third line your "y" became an "x". As far as what they want:
They asked for F(x,y)=G(x)+H(y)=K
So "Find such a solution" is satisfied by F(x,y)=-\mbox{arcsin}\left( \frac{x}{2}\right) + 5e^{2y} = K
but the answer they want is "give the related functions requested"
so try G(x)= -\mbox{arcsin}\left( \frac{x}{2}\right) \mbox{ and }H(y)= 5e^{2y}
Ahhh, thanks so much everyone it was correct. weee
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
