Calc Fall of Object from Space: Derive Eqn of Accel as Fxn of Time
  • Thread starter Thread starter recon
    Fall
To calculate the distance x from which an object falls to Earth in 17.5 hours, one must derive an equation for acceleration as a function of time. The acceleration is influenced by the gravitational force, which varies with distance from the Earth's center, described by the equation dv/dt = GM/r^2. To solve this, one can relate acceleration to velocity and distance using the chain rule, leading to v(dv/dr) = GM/r^2. The challenge lies in solving the resulting differential equations to express velocity as a function of distance and subsequently time. Understanding these relationships is crucial for determining the initial distance x.
recon
If it takes an object at distance x from the surface of the Earth 17.5 hours to fall from space onto the surface of the Earth, how can we calculate x? The object initially has zero speed.
I find this question hard because I've only done problems involving acceleration as a function of time, and not as a function of distance. :redface: Can anyone show me how to derive an equation of acceleration as a function of time?
You can use \frac{dv}{dt} = (\frac{dv}{dr})(\frac{dr}{dt}) = v \frac{dv}{dr}
So I think from this you can first find v(r) and then r(t) and use that to find x.
The first thing you may want to realize is that acceleration is a function of distance between the object and the center of the earth, and that the distance is a function of time.
I know \frac{dv}{dt} = \frac{GM}{r^2} but I can't figure out how this may be used to obtain v as a function of r.
How is it possible to solve the equation \frac{d^{2}r}{dt^2}=\frac{GM}{(R+r)^2}, where R is the radius of the Earth? I have not had much calculus yet, so I have not touched on solving differential equations of this difficulty.
You have
Now, as I said in my previous post,
So,
v\frac{dv}{dr} = \frac{GM}{r^2}
Now, can you find v(r) from this diff equation?
