When to Use Kg vs G in Physics Problems?
  • Thread starter Thread starter pureouchies4717
In physics problems, the choice between using kilograms (kg) or grams (g) depends on the units of the quantities involved; consistency is key. The standard unit of mass in the SI system is the kilogram, but either unit can be used as long as all quantities are in the same unit. When dealing with acceleration and velocity, it's common to assign negative values for downward motion, but this can vary based on the problem's context. If velocity and acceleration are in opposite directions, they should have opposite signs. Understanding these unit conventions and directional assignments is crucial for solving physics problems accurately.
pureouchies4717
hi. i always thought that g was standard in all problems, until i started learning about tension and other forces, where kg is needed. can someone please clarify when i need kg and g? its for a test in an hour
also, when accel/velocity is pointing down, its negative right?
The standard system of units (called the SI units) actually includes the kilogram as the standard unit of mass. This standard unit system is often called the "meter-kilogram-second" or "mks" system.
You do not specifically need to use either g or kg in any specific problem; you just have to ensure that your units are consistent throughout the problem. If all of the quantities in a given problem are in kilograms, it's probably easier to use kilograms. If all the quantities in a given problem are in grams, it's probably easier to use grams. If some of the quantities in a given problem are in grams, and others in kilograms, you will need to ensure they are all in the same units (either g or kg, whichever you prefer), before continuing.
Acceleration and velocity are not universally defined in terms of "up" or "down." While it's conventional to use positive values for the "up" direction, and negative values for the "down" direction, problems can be worded in the opposite sense. A well-written problem should include information about which direction is represented with which sign, like the following:
a rocket launched upwards with an acceleration of +5 m/s2...
- Warren
thank you
so, when velocity and acceleration are in oppposite directions, that it is the only time that they need to be separate signs, right?
