Induced EMF and long steel beam
A 5.97 m long steel beam dropped from a height of 6.82 m induces an electromotive force (emf) due to its motion through the Earth's magnetic field, which has a horizontal component of 12.2 µT. The time taken for the beam to fall is calculated using kinematic equations, resulting in approximately 0.834 seconds. The magnetic flux is determined using the formula B*L, but the initial calculation of 72.8 is questioned. The discussion highlights the concept of "motional emf," emphasizing the need to consider the beam's speed as it impacts the ground. The conversation concludes with a request for further assistance in calculating the induced emf correctly.
Punchlinegirl
A 5.97 m long steel beam is accidentally dropped by a construction crane from a height of 6.82 m. The horizontal component of the Earth's magnetic field over the region is 12.2 \mu T. The acceleration of gravity is 9.8 m/s^2. What is the induced emf in the beam just before impact with the Earth, assuming its long dimension remains in a horizontal plane, oriented perpendicularly to the horizontal component of the Earth's magnetic field? Answer in units of mV.
I know that E= change in flux/change in time
To get the change in time I used the equation
x(t)= x_o +v_o*t +.5 gt^2
where x_o=v_o=0
and x(t)= 6.82 m.
solving for t gave me .834 s.
Then for the flux I think it's just B*L= 72.8... but I don't think that's right...
Can someone please help me?
review something called "motional emf." THere is a variation of the emf formula for a straight conductor moving through a magnetic field in terms of its speed. Then, all you need to do is find the speed of the bar as it reaches the ground.
I got it... Thanks!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
