Pauli Matrices: Troubleshooting a Non-Zero Commutator
mewmew
Ok, I have a stupid question on pauli matrices here but it is bugging me. In a book I'm reading it gives the equation [\sigma_i , \sigma_j] = 2 I \epsilon_{i,j,k} \sigma_k , I understand how it works and everything but I do have a question, when you have k=i/j and i!=j (like 2,1,2) you get a non zero commutator and yet \epsilon gives you 0. What am I missing here? Thanks
The i and j determine the value of k.
For instance if i and j are equal then obviously the commutator is zero and the \epsilon_{ijk} = \epsilon_{iik} = 0 so that's fine.
If i and j are different then k is the other value from {1,2,3}. To use your example, if i=2 and j=1 then k MUST be 3 to get a non-zero value of \epsilon_{ijk} (you don't put commas in the subscript by the way). Therefore [\sigma_{2},\sigma_{1}] = \epsilon_{213}\sigma_{3} = -\sigma_{3}
If it makes it easier, think about summation convention, so that the right hand side becomes
\epsilon_{ijk}\sigma_{k} = \epsilon_{ij1}\sigma_{1} + \epsilon_{ij2}\sigma_{2} + \epsilon_{ij3}\sigma_{3}
This means that when i isn't equal to j only one of those three terms remains non-zero otherwise k will be equal to either i or j. If i=j, then all three are zero.
The Levi-Civita symbol is zero if any of the 3 indices are the same. Calculate a few of those commutators and see if they equal the RHS for the kind of indices you picked and see if the relation holds if you want to see this for yourself.
Thanks, that clears it up.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
