This is - number of charges trough
  • Thread starter Thread starter something_about
    Charges
The discussion focuses on calculating the number of charges moving through a conductor's cross-sectional area over a specific time interval. It explains that if a wire segment has N charges per unit volume and an average velocity v, the total number of charges passing through the area A in time delta t can be expressed as N * A * v * delta t. The reasoning involves visualizing a cylindrical volume within the wire, where only charges within a certain length, determined by their velocity and time, can pass through a defined plane. This approach clarifies how the formula accounts for both the density of charges and their movement through the conductor. Understanding this concept is crucial for analyzing current flow in electrical circuits.
something_about
This is urgent - number of charges trough...
hello
I can't figure out why the next formula tells us the number of charges that move trough cross-sectional area of the conductor.
If a segment of wire has N charges moving with average velocity v, then in time [delta]t the number of charges is
N * A * v * [delta]t
A is the cross-sectional area of the conductor
N is number of charged particles per unit volume
thank you
The distance traveled by a charge in time \delta t is, on average, v\delta t[/tex]. <br /> <br /> Construct a plane that cuts through the wire normally. We want to count the number of electrons passing through this plane in some time \delta t. Now, if all the electrons have velocity v, then for an electron to pass through the plane at some time t, it must have been no farther back than v\delta t[/tex] at a time t-\delta t. In other words, only those electrons contained within the cylinder (for a wire of circular cross-section) of length v\delta t[/tex] and area A, at a time t-\delta t will be able to pass through the wall in the ensuing time \delta t[/tex]. This number is simply the product of the volume of this cylinder, Av\delta t[/tex] and the number density, N.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
