Zinc Coating: What Makes it Ideal for Steel Protection?
Zinc is widely used for coating steel due to its excellent corrosion resistance under normal atmospheric conditions. It forms a protective oxide layer that enhances its durability and prevents rusting. While zinc itself can corrode, it does so preferentially, sacrificing itself to protect the underlying metal, a process known as galvanic protection. This property makes zinc an ideal choice for applications like marine environments, where it can prevent corrosion of more valuable metals. Overall, zinc's ability to corrode in place of steel ensures long-lasting protection.
supasupa
Why Zinc is so commonly use coat metals such as steel? I know that its a good corrosion resistant metal to use but what properties of zinc make it good to use under normal atmospheric conditions?
Does it have to do with the oxide layer that it forms around it?
what are 'normal' atmospheric conditions?
it's not corrosion resistant, it corrodes in place of whatever you're protecting. For instance, out on fishing boats, we fix a couple zinc bars to the bottom of our skiff so that electrolysis won't corrode the aluminum, but will corrode the zinc bar instead.
