How to solve cube roots question ?
  • Thread starter Thread starter sunny86
    Cube Roots
To solve the cubic equation x^3 - 100x^2 - 7800x + 16300 = 0, numerical methods can provide approximate solutions, while Cardano's method offers an exact solution, albeit with complexity. The transformation x = y - a/3 simplifies the equation to y^3 + py + q = 0, where p and q are derived from the original coefficients. The solution can then be expressed using Cardano's formula, which involves cube roots and square roots. For further details, resources like MathWorld and specific mathematical literature can be consulted. Understanding these methods can aid in effectively solving cubic equations.
sunny86
Example :
I had think long time but still cannot find the way. Besides trial an error, is there anyway to solve this problem ?
thank you.
Mathematics news on Phys.org
There are numerical methods to get approximate solutions ...
For an exact solution you may find useful this
http://mizar.uwb.edu.pl/JFM/Vol12/polyeq_1.html"
For a given equation x^3+ax^2+bx+c=0, we can substitute x=y-\frac{a}{3}, which implies y^3+py+q=0, where p=b-\frac{a^2}{3}, and q=\frac{2a^3}{17}-\frac{ab}{3}+c. After further manipulation, one can retrieve x=\sqrt[3]{-\frac{q}{2}+\sqrt{(\frac{q}{2})^2+(\frac{p}{3})^3}}+\sqrt[3]{-\frac{q}{2}-\sqrt{(\frac{q}{2})^2+(\frac{p}{3})^3}}, which represents Cardan's formula.
thank guy ~
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
