What is the formula for the quantity of radium left after t years?
  • Thread starter Thread starter Jacobpm64
    Decay Half-life
Jacobpm64
(a) The half-life of radium-226 is 1620 years. Write a formula for the quantity, Q, of radium left after t years, if the initial quantity is Q0.
Check me on this one:
Q = (Q0 / 2(1620/t))
(b) What percentage of the original amount of radium is left after 500 years?
Check this one as well:
Q = (Q0 / 21620/500)
Q = (Q0 / 23.24)
Q = Q0 * 2-3.24
Q = Q0(0.1058)
10.6%
In part 'a', the exponent on the 2 should reflect the number of half-lives, which is the ratio of t/T1/2, where T1/2 is the half-life.
So after 1 half-life, Q/Qo= 1/2, and after two half-lives, Q/Qo= (1/2)2 = 1/4, . . .
In the part 'b', the half-life of Rn-226 is 1620 years, the point at which 50% would be remaining, and 500 years is less than 1/3 of the half-life, so does 10.6% look right?
In other words, you have the exponent "upside down". It should be
t/1620, not 1620/t.
how's this?
(a) Q = (Q0 / 2t/1620)
(b) Q = (Q0 / 2500/1620)
Q = (Q0 / 20.3086...)
Q = Q0 * 2-0.3086...
Q = Q0(0.8074...)
80.7%
Better. :approve:
Do you understand why it is t/1620 rather than 1620/t? The "half life" of a substance is the time it takes to degrade to half its original value. Every time one "half life" passes, the amount is multiplied by 1/2: if the original amount is M, after one "half life" the amount is (1/2)M. After a second "half life", it is (1/2)((1/2)M)= (1/2)2M. After a third "half life" we multiply by 1/2 again: (1/2)((1/2)2M)= (1/2)3M. That is, the exponent just counts the number of "half lives" in the t years. If the "half life" is 1620, that "number of half lives" is t/1620 so the amount will be (1/2)t/1620M= M/2t/1620.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
