How to Solve Problems Involving Relative Velocity: Hints and Tips"
Relative velocity problems involve adding velocity vectors to determine the resultant velocity of an object with respect to a fixed reference point. For the jet airliner, drawing vectors to represent its speed and the wind direction is a recommended approach to find the new ground velocity. In the rowboat scenario, understanding the boat's velocity relative to the water and the current's effect is crucial for calculating how far upstream the boat lands. Resources like HyperPhysics provide valuable explanations and examples for tackling these types of problems. Mastering the addition of velocity vectors is essential for solving relative velocity questions effectively.
wtf_albino
Hello all!
My physics teacher has been absent for about two days so i haven't been able to ask him any questions.
Basically I don't understand the concept of relative velocity. I couldn't even start one problem!
1) A Jet airliner moving intially at 300 mph due east enters a region where the wind is blowing at 100 mph in a direction 30.0 degrees north of esast. What is the new velocity of the aircraft relative to the ground?
For this question.. I am thinking i can draw some vectors to represent the information and just manipulate them to find the resultant vector(?) and would that be the final velocity? You don't have to solve it for me.. would just appreciate a hint to a step in the right direction.
2) A rowboat crosses a river with a velocity of 3.30 mi/h at an angle of 62.5 degrees north of west relative to the water. The river is 0.505 mi wide and carries an eastward current of 1.25 mi/h. How far upstream is the boat when it reaches the opposite shore?
My book is very vague in explaining these types of problems! For this problem i drew it out successfully.. but i have no idea how to attack it! if someone could point me in the right direction I am positive i could solve it on my own thanks!
thanks in advance! i really appreciate your guys' help it's been a lifesaver. :biggrin:
well i forgot how to do this but
http://online.physics.uiuc.edu/courses/phys101/fall05/physics_101_lectures.html
I remb learning in the first few lectures and we did the same exact problems so just look at the completed PPT
thanks a lot alt! ill definitely look through the lesson.
i found the lesson about relative velocity.. the questions were rather simplistic though. are you sure it had similar questions?
One simply adds the velocity vectors.
If one is given the velocity of a vehicle (windspeed of aircraft in air, speed with respect to water of a boat) with respect to the fluid, and the fluid itself has some velocity, then add the two vectors to get the resulting velocity of the vehicle with respect to the fixed reference (usually land). The coordinated system orientations must be consistent however.
See -
http://hyperphysics.phy-astr.gsu.edu/hbase/relmot.html
http://hyperphysics.phy-astr.gsu.edu/hbase/airpw.html
http://hyperphysics.phy-astr.gsu.edu/hbase/boatc.html
Va + Vb = Va/b
