Seemingly Simple - How Many Orbits? (Rotational Kinematics)
The discussion centers on calculating the number of orbits an electron makes around a proton in a hydrogen atom based on the Bohr model. The user correctly determined the angular velocity of the electron as 5.15e15 rad/s but incorrectly converted this to revolutions per second as 8.09e15 rev/s. A participant points out that it is impossible to have more full revolutions than radians in the same time frame, indicating a flaw in the conversion process. The conversation emphasizes the importance of accurate unit conversion in rotational kinematics. Understanding these principles is crucial for solving similar physics problems effectively.
kmj9k
This is the latest question I've been stuck on.
The Bohr model of the hydrogen atom pictures the electron as a tiny particle moving in a circular orbit about a stationary proton. In the n=2 orbit, the distance from the proton to the electron is 21.16e-11 m , and the linear speed of the electron is 1.09e6 m/s.
How many orbits about the proton does it make each second?
Now, I found the angular velocity of the electron and got that correct: 5.15e15 rad/s. Now, to find the # of orbits, shouldn't I just convert to revolutions per second, which is 8.09e15 rev/s? The computer tells me I'm wrong, however, but I don't know what I could do differently.
Again, I appreciate your time!
I promise you that it is impossible to do more full revolutions than radians in the same amount of time. Your angular velocity looks good; your conversion does not.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
