Is My Reasoning Incorrect? A 5-ary Tree with 4n+2 Vertices
  • Thread starter Thread starter 0rthodontist
    Tree
0rthodontist
This was a question on the combinatorics midterm: if a tree contains only vertices of degree 5 and degree 1, and the tree has 4n+2 vertices, how many vertices of degree 5 are there?
With k the # of vertices of degree 5 and j the # of vertices of degree 1, the accepted answer used the formulas 5k + j = 8n + 2 (in other words sum over degrees of vertices = 2e) and k + j = 4n + 2 to reach the conclusion k = n.
I used the (fact)? that a 5-ary tree with k internal vertices has 5k + 1 total vertices, to get k = (4n+1)/5. This was marked wrong. I believe that the contradiction between the two answers shows that there is no 5-ary tree with 4n+2 vertices for any n. Is my reasoning incorrect? Is there a 5-ary tree with 4n+2 vertices? Maybe I am confused.
Ah, I got it. A tree with all vertices of degree 5 or 1 is not usually a 5-ary tree.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
