Need advice on data converter boards (ADC & DAC)
The discussion focuses on selecting suitable ADC and DAC boards for a digital radiometer, emphasizing the need for specific technical requirements. The desired ADC features include a single input, 12-16 bit resolution, high signal-to-noise ratio, low power consumption, and a throughput of over 80 megasamples per second. Similarly, the DAC should have a single output and match the resolution and power specifications of the ADC. A recommendation for starting research is provided, specifically mentioning National Instruments and a specific ADC model, the ADS7841. The thread seeks further suggestions for compatible ADCs and DACs that meet these criteria.
LaVic
Hello Everyone,
I would need some advice on what type of down converting analog to digital Converter (ADC) board and an digital to analog converter (DAC) board to use for my digital radiometer. Here are the specs for my ideal boards:
Analog to Digital Converter requirements:
  • Single Input
  • 12-16 Bit Resolution Output
  • High Signal To Noise Ratio (SNR)
  • Low Power Requirement (with one power supply preferably)
  • 80+ megasamples/second throughput/sample rate
  • Overall the ADC needs to be ideal for IF sampling applications.
Digital to Analog Converter requirements:
  • Single Output
  • 12-16 Bit Resolution Input
  • Remaining requirments are similar to the one of the ADC
Are there any ADCs and DACs out there that could fulfill the above stated requirements? I would appreciate any feedback! Thank You!
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
