Calculate Glass Volume Expansion Coefficient | Thermodynamics Question
  • Thread starter Thread starter tanky322
To calculate the coefficient of volume expansion of glass, the formula used is deltaV = (Beta)(Vo)(delta T), rearranged to Beta = (Delta V)/((Vo)(delta T)). The initial volume of the glass flask is 1000.0 cm³, and upon heating from 0.0°C to 80.0°C, 12.5 mL of mercury overflows. The calculated coefficient of volume expansion for the glass is 1.56 x 10^-4. Additionally, the expanded volume of mercury and the volume of the heated glass flask must be considered to ensure accurate results. This approach confirms the relevance of both the glass and mercury in the calculations.
tanky322
A glass flask whose volume is 1000.0 Cm^3 at 0.0 DegC is completley filled with mercury at this temperature. When the flask and mercury are warmed to 80.0 DegC, 12.5 ML of mercury overflow. Compute the coefficient of volume expansion of the glass.
I believe this is the formula I want to use deltaV=(Beta)(Vo)(delta T). Solving it for beta would bring me to Beta=(Delta V)/((Vo)(delta T)). I believe that the mercury shouldn't have anypart in this calculation but I am not too sure.
I plugged in all the good stuff and came out with an answer of 1.56 X 10^-4. Does this seem right?
What is the expanded volume of the mercury (use the coefficient of volume expansion for Hg and apply that to the temperature change).
What is the volume of the heated glass flask (ie. it contains all but 12.5 ml of the expanded Hg)?
Work out the coefficent of expansion for the glass using that information.
AM
Thanks! Its been a few months since I've done one of these just needed a little tip!
