Carnot cycle, heat and monatomic ideal gas
A monatomic ideal gas is utilized in the Carnot cycle, with isothermal processes A to B and C to D, and adiabatic processes B to C and D to A. The work done by the gas during the isothermal process A to B is 400 J, leading to the inquiry about the heat expelled during process C to D. The efficiency of the Carnot cycle is defined as 1 - (Ql/Qh) and 1 - (Tl/Th), indicating that the heat expelled must be less than 400 J. The final calculation determined that 100 J of heat is expelled during the process C to D, with an alternative solution found using the adiabatic equation. The discussion highlights the application of thermodynamic principles in solving the problem.
frznfire219
Hi, I would appreciate any help with this:
A monatomic ideal gas is used as the working substance for
the Carnot cycle. Processes A => B and C => D
are isothermal, while processes B => C and D => A are adiabatic.
During process A => B, there are 400 J of work done by the gas on
the surroundings. How much heat is expelled by the gas during process C => D?
So I'm completely stuck, all I know is that it's less than 400 J, obviously.
There's a picture of the corresponding PV graph actually at http://www.compadre.org/psrc/evals/Physics_Bowl_2003.pdf (page 12).
Thanks for any help!
anyone?
I'm not sure about this explanation, but whatever. You know that the carnot cycle runs at perfect efficiency ie. 1-(Ql/Qh) and you know that efficiency of the carnot cycle is also 1-(Tl/Th). I get 100 J.
Thanks! I actually figured it out later with the adiabatic equation (PV^gamma is constant) but your way is much more elegant.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
