Checking a Problem: Speed of Bending Rod Tip
  • Thread starter Thread starter Ja4Coltrane
    Bending Rod Speed
The discussion focuses on calculating the speed of the tip of a thin rod bent into a quarter circle with radius R as it rotates about the x-axis. The potential energy of the rod is calculated as U=(2/pi)MgR, and the moment of inertia is determined to be I=(1/2)MR^2. The final speed of the tip is derived as v=4[gR/pi]^(1/2) by equating the kinetic energy to double the initial potential energy. The calculations and assumptions made in this analysis are confirmed to be accurate.
  • Understanding of rotational dynamics and energy conservation principles
  • Familiarity with the concepts of potential energy and moment of inertia
  • Basic knowledge of calculus for integration techniques
  • Ability to interpret and manipulate equations in physics
  • Study the derivation of potential energy in rotating systems
  • Learn about the applications of the parallel axis theorem in moment of inertia calculations
  • Explore advanced topics in rotational motion, such as angular momentum
  • Investigate the effects of different shapes and masses on rotational speed
Physics students, mechanical engineers, and anyone interested in the dynamics of rotating bodies will benefit from this discussion.
Ja4Coltrane
I made up a problem and wanted to make sure that I did everything right.
A thing rod with mass M is bent into the shape of a quarter circle with radius R. It is positioned so that it looks like the arc made as theta moves from terminal position (+ x axis) to 90 degrees counterclockwise. I am going to let this arc rotate freely about the x-axis. My problem is to determine the speed of the tip of the wire when it has rotated all the way to the bottom.
First I calculated the potential energy of the rod using the x-axis as a refrence frame. I did this by integrating over the rod noting that the height of each piece is Rsin@
U=(2/pi)MgR.
Then I calculated the moment of inertia using the same integration techniques.
I=(1/2)MR^2
(Is that really true??!)
Finally I doubled the initial potential energy to get the kinetic when it has spun around and set that equal to (1/2)Iw^2
v=4[gR/pi]^(1/2)
If anyone would check this I would be very appreciative.
Should I perhaps move this question to a different forum?
define "thing rod"
403036387 said:
define "thing rod"
He means thin rod.
  • · Replies 31 ·
