Projectile motion - limited given data
The discussion focuses on a projectile motion problem involving a cannon firing at a 40-degree angle, with the projectile just clearing a net 6.0 meters away. Participants emphasize the need to determine the muzzle speed of the cannon and the height of the net using kinematic equations. The horizontal distance and vertical motion equations are highlighted, with the importance of calculating the time it takes for the projectile to reach the net. The conversation suggests setting up two equations of motion—one for horizontal distance and one for vertical height—while considering the projectile's velocity components. Overall, the problem requires careful algebraic manipulation of the equations to find the desired values.
Crilico
Basically, there is a projectile shot from a cannon. When shot, the projectile passes over a net, just barely, which is placed 6.0m away from the cannon, horizontally. The cannon is angled at 40 degrees above the x-axis.
The problem is asking for the muzzle speed of the cannon and how high the net is.
delta x = .5(Vf + Vi)t
Vf=at + Vi
delta x = .5at^2 + Vit
Vicos40 = X component Vi
Visin40 = Y component Vi
I know that delta x would be the 6.0m, X component acceleration is 0, and Y component acceleration is -9.8m/s^2. The problem i am running into is working with the limited number of givens here. I know i need to solve for the time it takes to travel to the net(6.0m horizontally). I'm sure it will involve several equations and substitutions to solve for algebraically(we are using non-calc methods in the course), but I'm not sure where to go with this problem.
I'd solve for muzzle speed first. you have the correct equations for the components of speed. Now you need to set up two equations of motion. The y-component should be set up for speed and the x component for distance. Now you know that at 6m in the x direction the y-component of velocity will be zero. You can rearrange these two equations to find the initial speed. Finding the height of the net from here should be simple.
what you do know is that at some unknown t, just as the ball misses the net,
t=6m/Vo*cos40
and Yo=Vo*sin40-.5at^2. Also tan 40=yo/6. Is that enough to do it?
