Solving Pendulum Dynamics on a Rotating Platform
The discussion focuses on solving the dynamics of a pendulum mounted on a rotating platform. The pendulum is 2 meters long with a mass of 1 kg, positioned 5 meters from the center of rotation, and makes a 30-degree angle with the pole at equilibrium. The key questions involve determining the angular velocity at equilibrium and the period of the pendulum when displaced. The user attempts calculations for angular velocity and considers replacing gravitational acceleration in the period equation due to the platform's motion. Guidance is provided to analyze the forces acting on the pendulum bob using Newton's second law, emphasizing the importance of separating vertical and horizontal components.
ataglance05
pendulum! help!
A pendulum 2 meters long with a mass of 1kg is mounted on a circular platform on the Earth's surface that's spinning at constant angular velocity. The pendulum is mounted on a pole that's perpendicular to the platform at a distance of 5 meters from the center of rotation. The equilibrium angle the pendulum makes with the pole is 30 degrees.
1) What's the angular velocity at equilirium?
2) If it's displaced for its equilibrium position, what will be the period of the pendulum?
a=F/m
a=v2/r
F=mv2/r
http://answerboard.cramster.com/Answer-Board/Image/cramster-equation-2007422035166331114291678125006410.gif
P.S. My physics teacher said that the diagrams below explains what's happening:
FROM A BIRD'S EYE VIEW-
http://answerboard.cramster.com/Answer-Board/Image/200743163856633112151365000000302.jpg
FROM A NORMAL VIEW-
http://answerboard.cramster.com/Answer-Board/Image/2007431724446331121788484375005079.jpg
1) R=5+r1
R=5+1= 6
h= l(1-Cos θ)
= 2(1-Cos 30degrees)
= .2679
http://answerboard.cramster.com/Answer-Board/Image/cramster-equation-20074317292633112181428593750754.gif
v=2.29 m/sec
ω=V/r
ω =2.29/1= 2.29 rad/sec
2) Now, my teacher said something along the lines of that I have to replace the acceleration due to gravity (g) in the period equation with an acceleration. Ergo, the equation would appear like this: http://answerboard.cramster.com/Answer-Board/Image/cramster-equation-2007431735306331121853068750002401.gif .[/URL] Now I know that it doesn't seem right, but take in mind that the circular platform is moving, not the pendulum its self.
So, I am not sure which acceleration I should use since I somehow have 3:
1)F=mv2/r a=f/m
F=1(2.29)2/6= .874 N a=.874 m/sec2
2)a1: Sin θ= opposite/hyp.
Sin 30degrees(9.8)= 4.9 m/sec2
3)a2: Cos θ=adjacent/hyp.
Cos 30degrees(9.8)= 8.49 m/sec2
Do I even use an acceleration in place of g or just use g??
anyone??:cry:
ataglance05 said:
1) R=5+r1
R=5+1= 6
This I understand. But the rest I don't.
h= l(1-Cos θ)
= .2679
v=2.29 m/sec
ω=V/r
What does "h" represent? That equation relating speed to height has to do with the energy of a falling body--not relevant here!
Instead, analyze the forces acting on the pendulum bob. There are only two: The tension in the cord and the weight of the bob. Hint: Analyze vertical and horizontal components separately. Apply Newton's 2nd law.
