Question about temperature measurements
The discussion centers on the distinction between shade temperatures and those measured under direct sunlight. Shade temperatures, which are typically lower, are taken in ventilated white shelters, known as Stevenson Screens, positioned about 1.5 meters above the ground. These shelters are designed to minimize sunlight absorption and maintain air circulation, preventing greenhouse effects. However, the effectiveness of these shelters can diminish over time due to factors like dirt accumulation. There is no specified ventilation rate for these shelters, and while forced ventilation exists, it is not commonly used. Additionally, meteorological temperatures are influenced by both true air temperature and wind speed, indicating that they do not represent pure air temperature readings.
Simfish
Used in measured highs/lows/hourly temperatures.
Are they shade temperatures or temperatures under the Sun? Also - are shade temperatures really cooler than temperatures under the Sun?
Yes, they are shade temperatures, and yes, these are often much lower than a reading under direct sunlight. A temperature measurement under direct sunlight will only tell you the temperature of the thermometer itself, not the air temperature.
http://www.rickly.com/MI/InstrumentShelter.htm
When I was in high school, they used to call those things Stevenson Screens.
All official measurements are taken about 1.5 meters above the ground, in a white shelter that is ventilated at a certain rate. The white color (ideally) gives the shelter a very high albedo, close to 100%, which means that it won't absorb sunlight and warm up... the ventilation keeps the air mixed and fresh (think greenhouse effect, or lack thereof).
Unfortunately, this can lead to problems... you can imagine that shelters don't stay perfectly white throughout their existence, for instance.
What rate is that? When was such a specification added? How are "corrections" made for "unventilated" data collected prior to that time?
For the record, there is no ventilation rate specified; there are forced ventilation shelters available, but they are not in common use.
"100%?" "Certain conditions and restrictions apply. Substantial penalties for early withdrawal, or in other random events." This is for chalk, clay, lead, or titanium whites? Oil, resin, lacquer, enamel, or latex bases? 5800 K emissivities run 0.1 - 0.3; 300 K emissivities run 0.6 - 0.8; temperature rises can get to 5 - 10 K in still air.
Meteorological temperatures are NOT true air temperatures; they are a combination of true air temperature and wind speed.
Thread 'The Secrets of Prof. Verschure's Rosetta Stones'
(Edit: since the thread title was changed, this first sentence is too cryptic: the original title referred to a Tool song....) Besides being a favorite song by a favorite band, the thread title is a straightforward play on words. This summer, as a present to myself for being promoted, I purchased a collection of thin sections that I believe comprise the research materials of Prof. Rob Verschure, who at the time was faculty in the Geological Institute in Amsterdam. What changed this...
These last days, there is a seemingly endless cluster of rather powerful earthquakes close to the islands of Santorini, Amorgos, Anafi, and Ios. Remember, this is a highly volcanically active region, Santorini especially being famous for the supervolcanic eruption which is conjectured to have led to the decline of the Minoan civilization: https://en.m.wikipedia.org/wiki/Minoan_eruption To grasp the scale of what is happening, between the 26th of January and the 9th of February, 12000...
