Calculate Signal Power from dBm vs Wavelength Graph
  • Thread starter Thread starter n0_3sc
    Energy Signal
n0_3sc
I have a graph of "dBm vs Wavelength".
I want the total Power in a certain area of the graph.
Do I convert the graph to:
"Power (Watts) vs Wavelength" then just Integrate within the required wavelength region?
ie.
\int_{\lambda_1}^{\lambda_2} Power d\lambda = Total Power
The way you described, you'll get some quantity with dimensions "power x length", which is not "power". If you had a graph of "Power per unit wavelength vs Wavelength", then you could integrate and obtain total power in the region of your choice. For example, see Planck's law in Wikipedia or somewhere else.
You have not sufficiently described the quantity on the y-axis. Besides, are you sure it's not in units of dBm/Hz or somesuch? It is meaningless to speak of power at a given wavelength or frequency.
The y-axis is a power measurement. It is in decibels with respect to a milliwatt (dBm).
Yes it is meaningless to talk of power per nm...
I realized now that it just needs to be some form of energy unit because it will be used as a ratio with other quantity's of the same units thus the units end up cancelling.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
