How Far Below the Cliff Top Do the Two Balls Cross Paths?
  • Thread starter Thread starter afcwestwarrior
A ball is dropped from a 24 m high cliff while a second ball is thrown upward with an initial speed equal to the impact speed of the first ball. The first ball accelerates downward at -9.81 m/s², starting from rest, while the second ball decelerates from its initial velocity. The two balls will cross paths at a height that can be determined by analyzing their respective motion equations. Since they travel for the same time, the distance traveled by the first ball plus the distance traveled by the second ball equals 24 m. The solution involves calculating the velocities and using kinematic equations to find the exact crossing point below the cliff top.
afcwestwarrior
A ball is dropped from rest from the top of a cliff that is 24 m high. From ground level, a second ball is thrown straight upward at the same instant that the 1st ball is dropped. The initial speed of the second ball is exactly the same as that which the 1st ball eventually hits the ground. In the absence of air resistance, the motions of the balls are just reverse of each other. Determine how far below the top of the cliff the balls cross paths.
Height= 24 m
y=1/2 (Vo + V) t
y= Vot + 1/2at
V^2= Vo^2 + 2ay or y=V^2 - Vo^2/2a
What equation should I use.
Well first, determine the velocity of the 1st ball.
It drops 24 m with an acceleration of -9.81 m/s2.
The initial velocity of a ball that is 'dropped' is zero.
The 2nd ball travels vertically with an initial velocity and decelerates.
See -
http://hyperphysics.phy-astr.gsu.edu/hbase/traj.html#ffall
The first ball is increasing speed and the second ball starts with a velocity and decreases in speed. One travels a distance h and the other a distance 24-h in the same amount of time.
