The Power of Salt Water: Harnessing Hydrogen & Oxygen
The discussion centers on a new method for separating water into hydrogen and oxygen using an RF generator, as reported by Scripps Howard. This process involves weakening the bonds in salt water, allowing hydrogen to be released and ignited, producing a flame that exceeds 3,000 degrees Fahrenheit. While the potential for this method as a power source is highlighted, concerns about energy efficiency are raised, questioning whether the energy input from the RF generator outweighs the energy output from burning hydrogen. The conversation also touches on the fundamental laws of thermodynamics, suggesting that this process may not be a viable energy source. Overall, the topic invites further exploration into the efficiency and practicality of harnessing this technology.
LURCH
This article; http://www.shns.com/shns/g_index2.cfm?action=detail&pk=SALTASFUEL-09-10-07 , from Scripps Howard talks about what appears to be a new method for seperating Water into Hydrogen and Oxygen by exposing it to an RF generator.
From the Article:
Roy said the salt water isn't burning per se, despite appearances. The radio frequency actually weakens bonds holding together the constituents of salt water -- sodium chloride, hydrogen and oxygen -- and releases the hydrogen, which, once ignited, burns continuously when exposed to the RF energy field. Kanzius said an independent source measured the flame's temperature, which exceeds 3,000 degrees Fahrenheit, reflecting an enormous energy output.
The article seems to make a big deal out of the possible application of this development as a power source. At least there is one mention of the question of efficiency;
But researching its potential will take time and money, he said. One immediate question is energy efficiency: The energy the RF generator uses vs. the energy output from burning hydrogen
NOw, unless somebody changed the laws of Entropy while I wasn't looking, this process which starts with liquid water and ends up burning Hydrogen and Oxygen to produce water can't be a source of energy. Do you guys see anything I missed?
Thanks Berkman. I thought there would already ber a thread on this, but I didn't think to look in that Forum. Seems kinda obvious, now.
No worries. Pretty interesting subject, eh? I'm just glad that we have a place like the PF to provide such lucid commentary on subjects like this one.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
