Relativistic Group Velocity Calculation
neelakash
we are given that an electron and a proton have the same KE.We are to compare their phase and group velocity...
K=(γ₁-1)m₁c²=(γ₂-1)m₂c²
Now, I found it very problematic to extract the ratio of v₁/v₂ in terms of m₁ and m₂
So,I expanded the γ s binomially where the major contribution comes from the first few terms...It follows that group velocity if proton is much less than that of the electron...
Please tell me if I am correct and sggest any other possible ways...
Regards,
neelakash
Don't use v.
Use E=T+M and p=\sqrt{T^2+2M}.
but how would you compae between the group velocities?
Don't use v.
I hope your formula is pc=√[K(K+2mc²)] where K is the KE
But, p=γmv...so that you are to know γ if you want to know v
γ s are different for e and p...
neelakash said:
but how would you compare between the group velocities?
Sorry, I should have had T=\sqrt{T^2+2MT}.
I use T for KE, which is more common, and relativistic units with c absent.
v_P=E/p, and v_g=dE/dp=p/E.
You don't need gamma or v, but they are gamma=E/M and v=p/E.
Buddy,what you are using seems not quite effective here...Remember we are to compare between group and phase velocities of an e and a p whose KE are the same...And you have not used the fact that their KE are the same...
I am referring to another method...It is no approximation..stands on sheer logic...
1 stands for e and 2 stands for p
Now,(γ₂-1)/(γ₁-1)=m₁/m₂
=>(γ₂-γ₁)/(γ₁+γ₂-2)=(m₁-m₂)/(m₁+m₂)<0
Also,(γ₁+γ₂)>2
=> γ₂<γ₁
From which you can deduce the relation between group and phase velocity...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
