Formaldehyde and boiling points
  • Thread starter Thread starter giankyr
    Boiling Points
The discussion centers on determining the boiling points of formaldehyde solutions. A user references a source indicating that a 37% formaldehyde solution has a boiling point of 98 degrees Celsius. They seek additional information on the boiling points of solutions containing 37% formaldehyde with 1% methanol, as well as solutions with 26% and 23% formaldehyde. The user notes the importance of the boiling point elevation constant (K_b) for formaldehyde and mentions the boiling point of pure formaldehyde at approximately -19.3 degrees Celsius, with a molecular weight of 30 g/mol. They express confidence in using the boiling-point elevation equation, which includes variables for the van 't Hoff factor (i) and molality (M).
giankyr
Hi guys. I'm looking for boiling points of solutions with Formadehyde and Water.
I found on ilo.org (http://www.ilo.org/public/english/protection/safework/cis/products/icsc/dtasht/_icsc06/icsc0695.htm) the boiling point of the solution Formaldehyde 37% (and the rest Water), it's 98 Degrees Celcius.
I would like to know the boiling point of a solution with Formaldehyde 37%, Methanol 1% (and the rest water), as well as of the Formaldehyde 26% or Formaldehyde 23% (and the rest water).
Chemistry news on Phys.org
You need to have the boiling point elevation constant K_{b} for formaldehyde I believe.
Now, I'd expect the boiling-point elevation equation to work -
\DeltaT_{b} = i K_{b} M
i is 1 for all non-electrolytes.
M is the molality, moles of solute/kg of solvent
Boiling point of pure formaldehyde is around -19.3 celsius, 30g/mol
Hope this helps!
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
