Speed & Distance to rotate 360 degrees
A vehicle cannot achieve a 360-degree rotation at normal highway speeds on a .7f coefficient of friction curved ramp without an external force. The friction level is insufficient for such a rotation solely from driver input. To reverse the direction of rotation, the driver would need to apply a significant lateral force through rapid steering, causing the vehicle to lose traction. The distance required for this maneuver will vary based on the vehicle's speed and the lateral force applied. Overall, achieving these rotations relies heavily on external factors and the vehicle's dynamics.
Crashman
I have a two part problem to figure out regarding a vehicle loosing control without any outside force except driver input in which it rotates 360 degrees in one direction on a .7f coefficient of friction curved narrow exit ramp. What speed and over what linear distance would be required to achiev this?
Second, what would be required in order to stop the rotation in one direction and begin to rotate 360 degrees in the opposite direction, again with any outside force except for driver input and what distance would that take?
I don't believe that a 360 degree rotation can be accomplished at normal highway speeds without some sort of an impacting force from another vehicle on a .7f roadway. This could probably be accomplished on ice (.01f) rather easily. I believe that the vehicle will begin to yaw and complete only a partial rotation prior to it running off of the road. I also believe that once rotating in one direction the vehicle could not be made to rotate in the opposite direction simply by driver input. Am I right? Why?
Roland
's answer is correct - a 360 degree rotation cannot be achieved at normal highway speeds without some sort of an impacting force from another vehicle on a .7f roadway. The amount of friction present on the curved narrow exit ramp is not sufficient for a vehicle to rotate that far in one direction without outside influence. In order to stop the rotation in one direction and begin to rotate 360 degrees in the opposite direction, a significant amount of lateral force would need to be applied by the driver. This could be done by making a rapid steering input, which would cause the vehicle to lose traction on the side with the most friction and begin to rotate in the opposite direction. The exact distance required to complete the rotation would depend on the speed of the vehicle and the amount of lateral force applied by the driver.
