Find the magnitude of the force exerted on the stick by the bowling ball
To find the force exerted on the stick by the bowling ball, the weight of the stick is calculated as 2.1266 N using its mass and gravitational acceleration. The torque equations indicate that the sum of torques must equal zero, leading to the conclusion that the force from the bowling ball acts perpendicular to the stick. The diameter of the bowling ball is relevant for determining the contact point with the stick, which affects the angle of force application. A diagram illustrating all forces acting on the stick, including gravitational and contact forces, is essential for solving the problem accurately. Understanding these principles is crucial for correctly calculating the forces involved.
Jacque77
A stick with a mass of 0.217 kg and a length of 0.435 m rests in contact with a bowling ball and a rough floor, as shown in the figure below. The bowling ball has a diameter of 21 cm, and the angle the stick makes with the horizontal is 30°. You may assume there is no friction between the stick and the bowling ball, though friction with the floor must be taken into account.
(a) Find the magnitude of the force exerted on the stick by the bowling ball.
(b) Find the horizontal component of the force exerted on the stick by the floor.
(c) Repeat part (b) for the upward component of the force.
for part a
sum FX=Gx(the Ground)-P(force at BBall) = 0 Gx=P
sum FY=Gy(the Ground)-Ws(stick weight) = 0 Gy=Ws
sum of the torques is zero
.217kg*9.8m/s = 2.1266N
Ws=2.1266Ncos 30 = 1.8417 = -Wstick*Lstick
P = .435m*sin 30 = .2175
so sum of torques is -Wstick*Lstick+PLp
P = 2.1266N*.2175m(mid stick)*cos30 / .435m*sin 30 or .4006/.2175 = 1.8418N
is the diameter number extra info or am I missing something here? This is a first attempt
for me at a problem like this, I am probably off-base?
Some things to consider: The force that the ball exerts on the stick is perpendicular to both (figure out the angle it makes with the horizontal). Use the diameter of the ball to figure out where the ball makes contact with the stick (it's not at the end).
Stick & Bowling Ball
The angle of the stick with the floor is given at 30 degrees
The angle of the stick resting on the bowling ball is 60 degrees
The diameter of the bowling ball is given at 21cm so the radius is half that at 10.5cm
(.217kg)*9.8m/s = 2.1266N
.217kg * cos 60 = .1085kg
.217kg * cos 30 = .1879kg
.217kg * sin 30 = .1085kg
since the torque = 0 the sum of the forces should = 0
What do I do next?
OK.
Not sure what you mean here. If you draw a line from where the stick touches the ball to the center of the ball, that line will be perpendicular to the stick.
OK
That's the weight of the stick. Where does it act?
Not sure what you're doing here.
What do I do next?
Yes, the sum of the torque = 0 and the sum of the forces = 0.
The first thing you need to do is draw yourself a diagram showing all the forces acting on the stick:
-- force of the ground, which has a vertical and horizontal component
-- force of gravity: Where does it act? What torque does it produce?
-- force of ball, which has a vertical and horizontal component: Where does it act? What angle does it make with the horizontal? What torque does it produce?
