Electric field and point charge problem
A particle with a negative charge moves towards a fixed positive point charge, starting from rest at a distance R on the x-axis. The force acting on the particle is derived as F = Qq/(4πE₀R²) in the negative x direction, confirming that the motion is constrained to the x-axis. The energy conservation law is expressed as (1/2)m(dx/dt)² + qQ/(4πE₀|x|) = E = constant, requiring the use of the time derivative to demonstrate its validity. The discussion emphasizes that the particle's trajectory remains linear due to the absence of forces acting in the y-direction. To determine the time taken for the particle to reach the center, the energy conservation principle from part c can be applied.
zinedine_88
A particle with mass m and chare, q<0, moves in the field of a POINT charge Q>0, which is fixed in the origine of a cartesian coordinate system. The particle starts at REST in a distance R on the x-axis of a cartesian coordinate system : r(o)(vector) = Rix(vector), V(o) = 0
a) ... what is the force on the particle with charge "q" . Write down the equation of motion.
b) Show that the particle moves in a straight line along the x - axis!
C) prove the energy conservcation LAW :
[(m/2)(dx/dt)^2] + qQ / 4(pi)[E(not)]abs(x) = E = const!
d) how long does it take for the particle to reach the center ( where the charge Q sits)
a) - i thing that the force is F = Qq/4(pi)(E(not)(R^2)times(-ix) unit vector , because it is moving from the right to the center... since Q is fixed! but tell me if i am right or wrong please..
b) I have no idea how to prove that mathematically...obviously there is no reason that q should move along the Y axis... but don't know what to do...
c) it says that i have to use the time derivative of the expression above and to use the equation of motion for x to show that it vanishes.. i don't get that HINT :( we have to assume that X is bigger than zero
d) says that i have to use the energy conservation law from part c...
there is nothing like that in our book...idk..
please help me
b) Hello, you have a good start. You already showed that part b was true when you calculated the force. The force vector only has an x component, so the particle must only move along the x axis.
c) Remember that F = m \frac{d^2 x}{dt^2}. What did you get for part c as it is?
d) Yes, if you use energy conservation then you can figure out when the particles collide.
