Relationship of velocity of an electron/velocity of proton to mass ratio
The discussion focuses on deriving the ratio of the velocities of an electron and a proton after being accelerated through the same electric potential difference. Using the equation for kinetic energy, participants clarify that the velocity of each particle can be expressed as a function of its charge and mass. The correct expressions for the speeds are v_e^2 = -2q_eΔV/m_e for the electron and v_p^2 = -2q_pΔV/m_p for the proton. By taking the ratio of these two equations, the relationship between the velocities and masses can be established. The conversation emphasizes the importance of correctly applying the conservation of energy principle to arrive at the desired ratio.
sheri1987
Relationship of velocity of an electron/velocity of proton to...mass ratio
An electron and a proton, starting from rest, are accelerated through an electric potential difference of the same magnitude. In the process, the electron acquires a speed ve, while the proton acquires a speed vp.
(d) What is the algebraic expression for the ratio ve/vp of the speed of the electron to that of the proton? Express your answer in terms of the mass me of the electron and the mass mp of the proton. (Answer using m_e for me and m_p for mp.)
SO I need to write an equation relating Velocity of electron/ velocity of proton...I understand that much...but I am unsure where to start.
I think I need the equation 1/2mv^2 = -q (charge)deltaV(voltage)
by using the equation above I solved and got sqrt(2qdeltaV/m) ...I am not sure where to go next...? Can anyone help me out?
Yes, that's what you want to use.
Actually, you should get sqrt(-2qdeltaV/m). Then if q<0 (like it is for an electron) then deltaV>0 and the radicand is positive. And if q>0 (like it is for the proton) then deltaV<0, and again the radicand is positive. Just find expressions for the speeds of the proton and the electron, and take their ratio and you'll have it.
So you have used conservation of energy to almost correctly [note the sign correction] solved for the velocity of a generic particle of charge q and mass m (traveling at non-relativistic speeds). Let me write your equation out in a form that may be easier to work with;
v^2 = -2q\Delta V \cdot \frac{1}{m}
So now you want that ratio v_e/v_p. So you can now write two equations;
v_e^2 = -2q_e\Delta V \cdot \frac{1}{m_e}
v_p^2 = -2q_p\Delta V \cdot \frac{1}{m_p}
Can you take the next step?
Edit: Tom beat me to it!
