Calculate the energy in BTUs that is removed
  • Thread starter Thread starter jason.frost
    Energy
To calculate the energy in BTUs removed when cooling a ton of poultry from 20 degrees Celsius to 0 degrees Fahrenheit, it's essential to use consistent units throughout the calculations. The specific heat values provided are crucial, with 0.80 BTU/lb/°F for temperatures above freezing and 0.41 BTU/lb/°F for below freezing. The conversion of temperatures from Celsius to Fahrenheit is necessary for accurate results. The discussion emphasizes the importance of unit consistency and the correct application of the specific heat formula, Q = cmΔT. Ultimately, converting BTUs to kilowatts can be done using the equation kW = BTU/3414.
jason.frost
[SOLVED] Heat problem
The manager of a fried chicken place wishes to store a ton of poultry at 0 degrees Fahrenheit. Initially the poultry is at 20 degrees Celsius. Calculate the energy in BTUs that is removed in this cooling for storage process.
Assume that the poultry freezes at 32F
Given:
Latent heat: 99 BTU/lb
Specific heats: 0.80 BTU/deg F/lb (above freezing)
0.41 BTU/deg F/lb (below freezing)
Was not specifically given any but from the book I'm thinking...
Specific heat
Q = cm\DeltaT
Latent heat
L = \frac{|Q|}{m}
Would I even have to use anyone of those equations? I am already given the specific heat and latent heat so those should do me no good right?
\DeltaT = 20 - 0 = 20
Q = (.8)(2000)(20)
Q = 32000J
I know I should have to convert all fahrenheit to celcius.
I am really at a loss though what I can use to give me a final BTU. If anyone could give me a push I'd appreciate it. I have no other sources but Internet and the book so other books will not help at this point. Thanks.
Q = (.8)(2000)(20)
Q = 32000J
Then why don't you? Stick to some consistent set of units.
In the eqn Q = (.8)(2000)(20), where is the 2000 coming from? The 0.8 is in BTU/lb/F, but delta_t = 20...This is meaningless!
Change everything to one system of units.
Whoops...sorry I meant to put in what each letter stood for.
Q = cm\DeltaT
\DeltaT - change in temp
m - mass
c - specific heat (which is given)
1 ton = 2000 lbs = 907.184 kg
kW = Btu / 3414
Q = (.8 BTU/lb/F)(907.184kg)(20C)
Q =
Can I convert the BTUs to kW just by using the equation kW = BTU/3414?
1 ton = 2240 lb = 907 kg.
As I said, convert everything to one system of units. Sp heat is given in BTU. Temp change in C can be easily converted to F. Use whichever you like.
Yes.
