Calculate Power Transported in Example 7.13 Cables w/V & I
  • Thread starter Thread starter JohnDuck
    E&m
JohnDuck
Calculate the power transported down the cables of Example 7.13 assuming the two conductors are held at potential difference V and carry current I.
The cable in example 7.13 is "a long coaxial cable" with inner radius a and outer radius b.
Poynting's Theorem: \frac{dW}{dt} = -\frac{dU\sub{em}}{dt} - \int{\vec{S}\vec{da}}, where S is the Poynting vector and the integral is over a closed surface.
Not confident my solution is correct. Seems somehow too easy. The first term of the LHS disappears because there is no time dependence. E is parallel to the z axis and has magnitude V/L at the surface of the outer wire, while B is circumferential and has magnitude \frac{\mu I}{2\pi s}. Thus S points radially inward and has magnitude \frac{VI}{2\pi sl}. The integral should be evaluated at the outer surface (s = b) over a cylindrical section of length L, yielding:
\int{\vec{S}\vec{da}} = S2\pi bL = VI
Like I said, I'm not confident my solution is correct (the book is very sparse on examples), and I'd like someone to confirm whether it is correct or incorrect.
You solution is indeed correct :approve:. You should have more confidence in yourself!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
