Entropy of a system can never decrease
  • Thread starter Thread starter shenwei1988
    Hard Heat
The discussion centers on the principles of thermodynamics, specifically the concept of entropy. It asserts that the entropy of a system can never decrease, aligning with the second law of thermodynamics. Key points include the reversibility of Carnot engines, the impossibility of heat transfer from a cold to a warm reservoir without work, and the impact of adding heat to an ideal gas on its entropy. The conversation emphasizes the importance of understanding these concepts through thoughtful inquiry rather than seeking quick answers. Engaging with the material is encouraged for deeper comprehension.
shenwei1988
heat! so hard.
true or false
1.The entropy of a system can never decrease
2.All Carnot engines are reversible
3.It is impossible have a net transfer of heat from a cold reservoir to a warm reservoir
4.A refrigerator lowers the entropy of the volume inside
5.If the temperature of the cold reservoir increases with the temperature of the hot reservoir unchanged, the efficiency of a Carnot engine will increase
6.Adiabatic expansion will lower the temperature of a gas
7.Any process that includes adding heat to an ideal gas will increase the entropy of the gas
8.All Carnot engines are more efficient than all real engines
No one will do your work for you.
If you have a genuine interest in knowing the answer to these questions you must show that you have actually thought about them, also ask them one or two at a time with effort given on each. Good luck.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
