Solve Infinite Summations w/o Pi: Tips & Tricks
  • Thread starter Thread starter mathg33k
    Infinite
mathg33k
Looking for ways to solve infinite summations, I found an ancient topic here talking about solving infinite summations that come out to answers with pi.
How would I solve an infinite summation that does not come out to an answer with pi?
Such as:
\sum_{n=1}^{\infty}\frac{n+1}{6^n}
The solution is 11/25, btw.
My attempt: I am not really experienced with this area of math, so what I did was put it into my TI-nSpire but it couldn't do it because it's not the CAS version. I plugged in a large number such as 999 terms instead of infinity terms and it came out to the right answer, but I am looking for a more "correct" way to solve the problem. I also thought of finding the sum of a geometric sequence but I realized that doesn't really work for most summations.
Oh, I'm also new to these forums, so hi to everybody! =D
EDIT: The n under the summation should say n=1
Many of these problems can be solved by recognizing that your series is actually a special case of a more general one.
One of the more useful series is the geometric series: If |x|<1,
\sum_{n=0}^{\infty} x^n = \frac{1}{1-x}.
It's not immediately obvious how we can use this to evaluate your series. However, there's a nice trick: Differentiate both sides of the above equation term by term to get (for |x| < 1):
\sum_{n=1}^{\infty} n x^{n-1} = \frac{1}{(1-x)^2}.
Can you take it from here?
Likes 1 person
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
