Understanding Rotation Matrices for nxn Orders
The discussion centers around the representation of rotation matrices for n-dimensional spaces, exploring their forms in various dimensions and the mathematical properties associated with them. Participants delve into theoretical aspects, applications, and implications of rotation matrices in both geometric and algebraic contexts.
  • Some participants describe the 2D rotation matrix as a standard form involving cosine and sine functions, while others seek to extend this understanding to higher dimensions.
  • One participant suggests that any matrix with a determinant of 1 can represent a rotation, prompting further exploration of the properties of such matrices.
  • A participant proposes a geometric-algebra approach to express rotations in R^N, involving complex exponentials and bivectors, indicating a more advanced mathematical framework.
  • Another viewpoint presents a method of decomposing a vector into components parallel and perpendicular to the plane of rotation, using projections to compute the rotation matrix.
  • Some participants assert that a rotation matrix is an orthogonal matrix with a determinant of one, suggesting a specific structure in certain bases.
  • There is a discussion about the relationship between homotopy and rotation matrices, particularly in odd-dimensional spheres, indicating a connection to topology.
  • Participants raise questions about the minimum number of sequential plane rotations required to represent a general rotation in higher dimensions, noting that it varies with the dimension.
  • One participant mentions that in odd dimensions, the rotation matrix must include a 1 on the diagonal, while this is not necessary in even dimensions.
Participants express a range of views on the properties and representations of rotation matrices, with no clear consensus on the best approach or the implications of their findings. The discussion remains open-ended, with various competing models and hypotheses presented.
Some mathematical steps and assumptions underlying the proposed methods and representations are not fully resolved, leaving room for further exploration and clarification.
MathematicalPhysicist
I know how the rotation matrix looks like in the 2x2 and 3x3 orders, but how does it look in general?
thanks in advance.
I know that, in 2 dimensions, a rotation about (0,0) by angle [itex]\theta[/itex] can be represented as a matrix by
[tex]\left[\begin{array}{cc}cos(\theta) & -sin(\theta) \\ sin(\theta) & cos(\theta)\end{array}\right][/tex]
but what are you saying a rotation in 3 dimensions looks like?
Any matrix with determinant 1 can represent a rotation.
Think of a rotation as taking the x,y,z,w,... axes, and rotating them around to a new set of axes x2,y2,z2,w2,... If you take the unit vectors in the representing of the new axes, and put them in the columns of a matrix in their respective order, then that matrix you get will be the rotation matrix.
In R2, you may notice that the vector (cos(theta),sin(theta)) and (-sin(theta),cos(theta)) are perpendicular unit vectors rotated theta degrees from the original (1,0) and (0,1) vectors.
If you are looking for a R^N rotation in a plane, rotating the components of a vector that lies in the plane and leaving the "perpendicular" components (ie: components in all normal directions) untouched, then this can be expressed with the following geometric-algebra/clifford-product expansion:
[tex] R(x) = e^{-i\theta/2} x e^{i\theta/2}<br /> = x \cos^2(\theta/2) - i x i \sin^2(\theta/2) + 2 \cos(\theta/2) \sin(\theta/2) x \cdot i[/tex]
Here the unit bivector i is formed by the product of two non-colinear vectors n_k in the plane:
[tex] i=\frac{n_1 \wedge n_2}{\lvert n_1 \wedge n_2 \rvert}.[/tex]
It's a bit messy, but you can calculate the rotation matrix from this if you really wanted to (with an orthonormal basis basis e_i and calculation of R(e_i) \cdot e_j gives the matrix).
another way to look at this is, just like so:
[tex] R(x) = x_{\perp} + x_{\parallel}\left( cos\theta + i\sin\theta\right)[/tex]
where [itex]x_{\perp}[/itex] is the component not in the plane of rotation, [itex]x_{\parallel}[/itex] is the component in the plane of rotation, and [itex]x_{\parallel} i[/itex] is a 90 degree rotation in the desired sense of the component of the vector in the plane. Then given any way you are comfortable with (ie: projection and rejection matrixes P, and (I-P)) for finding the components of the vector in and out of the plane, you can use that to compute the rotation matrix.
i think a rotation is an orthogonal matrix with determinant one?
so there is some basis in which the matrix looks like a bunch of 1's on the diagonal, and then a bunch of 2 by 2 matrices representing plane rotations.
Yes, thanks mathwonk I also got this answer after solving a question from Gullimin and Pollack:" if k is odd then f:S^k->S^k f(x)=-x is homotpic to the identity function".
The homotopy is a sort of rotation matrix times x, where the argument is (pi*t), so if k is odd we can find a rotation matrix (k+1)x(k+1) (k+1 is even) which consists of orthogonal matrices on the diagonal representing plane rotations.
P.S
You got to love geometry! (-:
So that raises an interesting question - what is the minimum number of sequential plane rotations required to represent a general rotation in Rn?
In R2, its just 1. In R3 its 2 since you rotate xhat to xhat', and then roll around xhat'. What about higher dimensions?
Every plane rotation can be factored into two reflections. It might be easier to think in terms of reflections.
There's a really elegant derivation of this (i.e., the number of plane rotations needed to give a general rotation) in The Road to Reality using Clifford algebras, but I forget it.
well if we have R^n where n is odd, then there must be 1 in the diagonal of the matrix, while in an even n we can handle without it (if we want).
