Solving Flux of Electric Field through a Cube of Side L = 2m
  • Thread starter Thread starter ibaraku
    Cube Flux
The discussion focuses on calculating the electric flux through a cube with a given electric field. The total flux through the cube is determined by summing the contributions from each face, using the equation phi total = (E * n) delta A. Participants clarify that the flux is calculated using the dot product of the electric field vector and the normal vector for each face. It is emphasized that the flux will be zero for faces where the electric field is perpendicular, and the total flux through the cube sums to zero due to symmetry. The final goal is to find the individual flux values for each face rather than just the total.
ibaraku
A cube of side L = 2m is centered at the origin, with the coordinate axes perpendicular to its faces. Find the flux of the electric field E = (15N/C)i + (27N/C)j + (39N/C)k through each face of the cube
Ok, so I know that
phi total = phi 1 + phi 2 + ... + phi 6
what I am confused about is how do I know where the flux is parallel to the faces of cube, where is it zero?
Thanks
Ok, so I know that
Thanks
(E*n) is the dot product between \vec{E} and \hat{n}. You are given \vec{E}, so what is the defintion of \hat{n} for any surface? What is \hat{n} for each surface of the cube? Once you find these, you just compute the dot product and then integrate over the area of each surface to get your phis.
Yeah I get that
[((15N/C)i + (27N/C)j + (39N/C)k] . i = (15N/C) a^2
"" "" "" "" . -i = -(15N/C) a^2
I am just wondering how do I know where one of this calculations will be zero, where will the flux be parallel to the sides of the cube, how do I recognize that?
ibaraku said:
Yeah I get that
Flux is a scalar quantity...it will be neither parallel nor perpendicular to any given side. Why do you have an a^2 there? And for which face is \hat{n}=+\hat{i}?Is it the same for all faces? Can you show your whole solution?
gabbagabbahey said:
What is \hat{i} \cdot \hat{i}, how about \hat{i} \cdot \hat{j} and \hat{i} \cdot \hat{k}?
1, 0, 0
I see, so for this problem
[(15N/C)a^2 + (-15N/C)a^2 + (27N/C)a^2 + (-27N/C)a^2 + (39N/C)a^2 + (-39N/C)a^2] = 0
Thanks
ibaraku said:
1, 0, 0
Thanks
If by a you mean L, then yes but you have calculated the TOTAL flux. The question asks for the flux through each side. You should draw a diagram, where you label each side and give the flux through each side.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
