What is the Moment of Inertia for a Rectangular Beam under Uniform Force?
The moment of inertia for a rectangular beam under a uniform force in the negative y-direction is discussed, focusing on its relevance in modeling beam deflection. The cross-sectional dimensions are defined as height (h) and width (b). The correct formula for the moment of inertia is confirmed to be bh^3/12, which pertains to bending stress. This value is essential for solving the differential equation E I (d4/dz4)u = w for beam deflection. Understanding this concept is crucial for accurate structural analysis and design.
Savage32
Rectangular Beam-
Cross section
h - dimension in y direction
b - dimension in x direction
If with a uniform force acting on the beam in the negative y-dir, what is the relevant moment of inertia when modeling the deflection u(z): E I (d4/dz4)u =w?
I believe it is bh^3/12, but I am not positive
Thanks in advance for any help.
Yes, you are correct. You are listing the Second Moment of Inertia (Area), which deals with bending stress.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
