Solving Oscillatory Motion: When Block B Starts to Slip?
The discussion focuses on determining the amplitude at which block B begins to slip during oscillatory motion, with no friction present between the large block and the surface. Participants emphasize the importance of understanding the forces acting on block B and how they relate to its acceleration. The key equation mentioned is F=ma, which suggests that the mass of block B will cancel out in the calculations. A participant expresses confusion about where to start but ultimately realizes that identifying the force responsible for accelerating block B is crucial. The conversation concludes with a participant indicating they have found a solution to the problem.
Tzar_MacEng
The amplitude of the oscillation gradually increases till block B starts to slip. At what A does this happen? (there is no friction between the large block and the surface)
Force equations etc... (F=ma) and
I reckon it has something to do with the force being combined with that a up there, but I have no clue where to start so that the mass of B cancels.
No dice :(
I hope I've done everything right, I couldn't find an equation editor, so I just used office suit's one and upped the pics of it.
Hi Tzar_MacEng,
What force is responsible for accelerating the small block? Can you relate that force to the acceleration you have already found?
Well, I haven't exactly found an acceleration, however I imagine it is going to something related to F=ma and the mass will cancel somewhere through substitution and algebra. I just can't figure out where to start.
Think about the question I asked: what force is actually repsponsible for accelerating the small block? Once you have the answer to that, you will know which extra formulas you need, and it will also explain why there is a largest amplitude in the first place.
I figured it out
