Equipartition Theorem and Microscopic Motion question
  • Thread starter Thread starter doggieslover
    Motion Theorem
The discussion centers on calculating the typical rotational frequency of the nitrogen molecule (N2) at room temperature. The participants debate the correct application of the mass in the angular speed formula, noting that the mass used should be for a single nitrogen atom rather than the entire molecule. There is confusion regarding whether to consider the three degrees of freedom in the calculations, which could affect the final frequency result. One participant arrives at a frequency of 6.69 x 10^6 Hz, while another suggests that the correct approach might yield a frequency of 2.00 x 10^8 Hz. Clarification on the mass and degrees of freedom is essential for an accurate calculation.
doggieslover
What is the typical rotational frequency f_rot for a molecule like {\rm N}_2 at room temperature (25\;^\circ \rm{C})? Assume that d for this molecule is 1\; {\rm \AA} =10^{-10}\; {\rm m}. Take the atomic mass of {\rm N}_2 to be m_{\rm N_2} = 4.65 \times 10^{-26}\; {\rm kg}.
Express f_rot numerically in hertz, to three significant figures.
I know that :
Boltzmann's constant = k_B = 1.38*10^-23 J/K
angular speed about the x-axis is omega = [(k_B*T)/(m*((d^2)/2)]^1/2
Rotational frequency = omega/ 2pi
Then I got 6.69*10^6 as the answer, I was wondering if it is correct, since I only have one more try left.
Or do I need to take the 3 degrees of freedom into consideration, so would the equation for omega then becomes [3(k_B*T)/(m*((d^2)/2)]^1/2, so the final answer for rotational frequency is 2.00*10^8 ?
Please help.
I think you should consider m - mass of N-2 first, then you apply it to the equation of omega to find omega and frequency.
Note: m in the omega formula is mass of only 1 atom while m given is the mass of Nitrogen molecule.
Hope this helps =)
But the mass of N_2 is already given in the problem.
That's what I said above. The m given is mass of N-2 molecule which has 2 atoms. The mass m in the omega formula is mass of 1 single atom, not a molecule, which means you have to divide the given m by 2.
Actually then do I still need to take the degrees of freedom into consideration other than the mass situation?
