Solving Algebraically for T2: Q Lost = Q Gained
  • Thread starter Thread starter Soliloquy12
    Lost
The discussion revolves around solving for T2 in a heat transfer problem using the equation QLost = QGained. The user derived an equation for T2 but encountered discrepancies in their results, obtaining T2 = 123.66°C from the original equation and T2 = 76.34°C from their derived equation. Other participants pointed out that the final temperature should logically fall between the two initial temperatures, suggesting a possible algebraic error in the user's calculations. They recommended clarifying the equation by adding parentheses for accuracy and urged the user to share detailed steps to identify the mistake. The conversation highlights the importance of careful algebraic manipulation in solving thermal equilibrium problems.
Soliloquy12
Solve algebraically for T2 then find T2.
T1C=63 Celsius
T1H=79.5 Celsius
MCW=8.63g
MBW=36.48g
QLost = QGained
-mbwcw(T2-T1H) = mcwcw(T2-T1C)
Trying to solve algebraically I arrived at:
T2 = mcwt1C+mbwt1h/(mbw+mcw)
But when substituting the values I get T2 = 123.66J from the original equation and T2 = 76.34 when using the equation I derived from the original.
Can someone please show me where I am going wrong with the equation here?
Thanks!
What do you mean? How exactly did you get that result? (I assume that's the final temperature of some mixture, not an energy in Joules.)
I didn't do the calculation, but if the problem is what I think it is, that sounds reasonable.
Yes sorry i meant degrees celsius. I substitutted the values into the initial "long" equation when I got 123.66 degrees celsius.
I still don't know what you mean. The initial "long" equation is the same equation that you rearranged to solve for T2. All you did was solve it algebraically--it's still the same equation.
Show exactly what you did. What values did you substitute?
Thanks!
First, I would suggest that you put parentheses around the two terms in your numerator for clarity and to prevent mistakes.
Second, I'm assuming that this problem involves adding something hot to something cool because you didn't really say. In problems such as that the final temperature will lie between the two starting temperatures. Therefore you should suspect that you made a simple algebraic error when you computed 123.66 degrees. As Dr AL indicated, without seeing the details of your calculation, one can't say more.
