Harmonic motion of a string - Find energy
In simple harmonic motion of a mass m hanging from a spring with spring constant k, the period T is defined by T=2*pi*sqrt(m/k). The elastic potential energy (PE) in the spring is calculated using PE=0.5kx^2, where x is the elongation. By substituting k from the period equation, PE can be expressed as PE=(4*pi^2*m*x^2)/(2*T^2). The total potential energy combines gravitational potential energy and elastic potential energy, represented as E_p = -mgx + 0.5kx^2, assuming gravitational potential energy is zero at x=0. The discussion clarifies the relationship between these energies in the context of harmonic motion.
UrbanXrisis
When a mass m, hanging from a string with spring constant k, is set into up-and-down simple harmonic motion, it has a period of vibration T, which is given by the equation T=2*pi*sqrt(m/k). The amount of elastic potential energy PE stored in the spring at any given instant is dependent on its spring constant k ant its elongation x. Determine the potential energy stored in the spring, PE, in terms of m, T, and x.
I got PE=mgh
m would be the mass in the string and h would be the elongation, but what about acceleration?
Use the equation T=2*pi*sqrt(m/k) and solve for k. Get that and sub in what you got for k into PE=.5kx^2
They don't give you a relation point for the gravitational potential energy, so I will assume it to be zero at x = 0. The total potential energy is the sum of the gravitational potential energy and the elastic potential energy:
E_p = E_{p_g} + E_{p_{ele}} = mgx + \frac{1}{2}kx^2
And K you can find from T.
Except of course you meant
E_p = E_{p_g} + E_{p_{ele}} = -mgx + \frac{1}{2}kx^2
:wink:
:wink:
Of course... I didn't notice x represented elongation, I just assumed the X axis pointed up.
