How do you calculate tension in the string?
  • Thread starter Thread starter hellokitty
    String Tension
To calculate the tension in the guitar string, first determine the wave speed using the frequency and the length of the string. The frequency of 420 Hz and three antinodes indicate that the string is vibrating in its third harmonic. The wave speed can be found using the formula v = f * λ, where λ is the wavelength corresponding to the length of the string. The tension can then be calculated using the formula T = μ * v², where μ is the linear density of the string. Understanding these relationships is crucial for solving the problem effectively.
hellokitty
A guitar string with a linear density of 2.0 g/m is stretched between supports that are 60 cm apart. The string is observed to form a standing wave with three antinodes when driven at a frequency of 420 Hz.
What is the tension in the string?
Please show us what you've tried so far.
I don't have any formulas to even begin solving the problem. i just know f= v/x an f= 1/period? My book does not have any formulas pertaining to tension and the teacher never taught us this information.
