Help with definate integration problem
  • Thread starter Thread starter crm08
    Integration
crm08
\int10^{t}dt t = [1,2]
I know that \int(a^{x})dx = \frac{(a^x)}{ln(x)} + C and x\neq 1
I could do this problem as indefinate, but since the restraints include a "1", I can't plug it into the the integral because it will result in a "0" being in the denominator. The answer in the back of the book shows:
\frac{90}{ln(10)}
Should I be using a substitution rule somewhere?
Well, the equation in your section 2 is actually incorrect, the x and a's should be switched around ( or the dx replaced with da). That solves the problem !
sorry never mind, its supposed to be the ln(a) not x
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
