What are some different ways to find the thickness of aluminum foil?
  • Thread starter Thread starter miss.fabulous
    Aluminum Thickness
Various methods to determine the thickness of aluminum foil include calculating volume and density, measuring weight and area, and using advanced techniques like beta-ray backscatter and X-ray fluorescence. Practical approaches involve folding the foil to increase thickness for easier measurement, using a micrometer, or applying Archimedes' Principle. It's also suggested to consider any non-aluminum coatings that may affect accuracy. Creative ideas include measuring resistance, tensile strength, or even comparing the foil's sink velocity with a paper airplane. Overall, multiple techniques can yield insights into aluminum foil thickness, enhancing understanding of material properties.
miss.fabulous
I have already calculated it by using the method that requires us to find the volume, given the density, and dividing it by area. So i need new ways to do this same problem.
Welcome to PF.
What if you have enough thicknesses to measure?
There are different ways to measure weight and volume, can you think of a few?
There is a more advanced way that you probably wouldn't think of -- go to www.wikipedia.org and search on Skin Depth. See if that gives you any ideas...
Also, "Aluminum Foil" may have a non-aluminum coating on it... you should read a bit about commercial aluminum foil to see if there are any other layers present that may cause your measurements to be less accurate... (maybe get extra credit for figuring that part out...?)
Fold until thick enough to measure accurately. Cut fold edge away with scissors. Measure and divide by number of layers.
You might be able to measure it directly with a micrometer.
Less practically for you, but:
- Beta-ray backscatter
- X-ray fluorescence
If it's a coursework project, you could certainly mention them!
"What are some different ways to find the thickness of aluminum foil?"
Write the manufacturer.
Ask someone in PF to measure it for you.
Bring in some really thin foil off a candy wrapper, and complain about it, until your teacher measures it for you.
Measure it's resistance.
Measure it's tensil strength.
Make an aluminum airplane and compare it's sink velocity to a paper airplane of the same dimensions.
Meaure it's heat capacity.
Transmutate one square inch of it into phosphorus with alpha radiation and weigh the phosphorus.
Make really big balls of it using half a roll of Renolds Wrap, and throw them it at your older brother until he exclaims, "Do you know how much that weighs?" Ask, "No, how much?" Retreat to your room with a worksheet and calculator.
It's so obvious so I assume it's already implicitly expressed elsewhere, but good ol' Archimedes Principle is a good port of call.
You might examine a thin cross-section under a high-powered microscope and calculate the thickness based on the magnification and focal length.
