How do I solve for the solutions of sin 2θ = sin θ in degrees?
  • Thread starter Thread starter patriots1049
    Trigonometric
To solve the equation sin 2θ = sin θ, the identity sin 2θ = 2sinθcosθ is used. This leads to the equation 2sinθcosθ = sin θ. By factoring out sin θ, it is determined that sin θ = 0 gives solutions of θ = 0° and θ = 180°. If sin θ is not zero, dividing by sin θ leads to cos θ = 1, which gives θ = 0° as well. The valid solutions within the range of 0° to 360° are confirmed to be 0° and 180°.
patriots1049
sin 2θ = sin θ Find the solutions in degrees.
sin 2θ = 2sinθcosθ
sin 2θ = sin θ
2sinθcosθ = sin θ
sinθ *cosθ/sin θ = 1
That's as far as I can get, and I think that is wrong. How do I procede from 2sinθcosθ = sin θ?
sin 2θ = 2sinθcosθ
sin 2θ = sin θ
2sinθcosθ = sin θ
One obvious possibility is sin(\theta)= 0. What values of \theta give that?
IF sin(\theta)\ne 0, you can divide by it.
So cancel the sin(\theta)s, giving cos(\theta)= 1[/math]. What values of \theta give that?<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> That&#039;s as far as I can get, and I think that is wrong. How do I procede from 2sinθcosθ = sin θ? </div> </div> </blockquote>
Therefore the answer would be 0 degrees and 180 degrees? The book states that answers must greater or equal to one and less than 360.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
