Predicting and Writing Net Ionic Equations for Chemical Reactions
The discussion focuses on predicting reactions and writing net ionic equations for various chemical scenarios. Participants identify that chromium reacts with silver nitrate, while gold in hydrochloric acid and nickel in calcium acetate do not react. The confusion arises when attempting to cancel spectator ions, as participants mistakenly treat solid and aqueous species as identical. Clarifications emphasize the importance of recognizing the different states and charges of ions, with suggestions to use oxidation numbers and the periodic table for guidance. Understanding these concepts is crucial for accurately writing net ionic equations.
mcandrewsr
For each of the following situations, identify those for which a reaction likely to occur. For those that do occur, white a net ionic equation.
a) Chromium dipped into silver nitrate.
b) Gold immersed in hydrochloric acid
c) Nickel pellets dropped into calcium acetate, Ca(C2H3O2)2.
d) Aluminum dropped into a bath of sulphuric acid.
e) Zinc dipped into a solution of lead(II) nitrate.
This is what I got:
a)Cr(s) + 2AgNO3(aq) --> Cr(NO3)2 + 2Ag(s)
Separate the aqueous ions:
Cr(s) + 2Ag(aq) + 2NO3(aq) --> Cr(aq) + 2NO3(aq) + 2Ag(s)
Then I'm supposed to remove the ions common to both sides...but
then I end up with none at all b/c each one is on both sides...?
b) no reaction
c) no reaction
d) 2Al(s) + 3H2SO4(aq) --> Al2(SO4)3(aq) + 3H2(g)
Here I get the same problem as in (a) when I separate them.
e) Zn(s) + Pb(NO3)2(aq) --> Zn(NO3)2(aq) + Pb(s)
Again, same problem...if I separate the aqueous ions and get rid of the common ones I end up with nothing.
What am I doing wrong? If someone can show me how to do this that would be great, thanks!
This is what I got:
b) no reaction
c) no reaction
Be careful when you cancel off spectator species, make sure that they are indeed the same thing!
Firstly, note that the silver and nitrate exist as IONS in solution i.e.:
AgNO3(aq) --> Ag+(aq) + NO3-(aq)
So make sure you include the charges. This then indicates that the silver (and chromium) species on each side are NOT the same i.e. Ag+(aq) is completely different from Ag(s), so you cannot cancel them off, so overall, you are left with:
Cr(s) + 3Ag+(aq) --> Cr3+(aq) + 3Ag(s)
How do I know the different charges of ions when they are in different states? Ex. How does Cr(s) have a different charge than the aqueous one? How do I figure this out for any others?
There are a set of elements that have set oxidation numbers (for example oxygen normally has an oxidation number of 2-). By using these, you can determine what the other charges are.
The Bob
Cr(s) is not ionic.
Otherwise - use periodic table. But some things you will just have to remember.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
